£2000-£3000 New build Help!
10 Aug 2013
I haven't designed my own PC in 3 years and looking at the components available I quickly realised I am majorly out of touch.
I bought a custom build off OC 3 years ago and it has served me well (still runs perfect only needed to change the hard drive in 3 years).
So basically, I have a budget of £2-£3k ( i've been saving up) and I really don't have time at the moment to research each part/compare. If anyone has some spare time and wouldn't mind posting a build that I could get from OCUK( I want to give them my business). I did look at the Ultima 460i Scimitar but I wasn't 100% sure it was actually worth the 3k (no blu ray, only 120gb ssd.. I could be wrong)
If anyone could post or PM me some build specs. I want it water cooled and I don't need any peripherals and I want it all from OCUK. Cheers and Hello :)
This is what ive been playing around with so far:
- Cooler Master Cosmos II Ultra Tower Case - Black (temporarily out of stock)
- Stage 3 Intel: Overclock of CPU - 4.4GHz Overclock - K Edition Processors Only
- Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - OEM
- Corsair Hydro H80i High Performance Liquid CPU Cooler
- Gigabyte Z87X-OC Force Intel Z87 (Socket 1150) DDR3 ATX Motherboard
- TeamGroup Vulcan RED 16GB (2x8GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLD316G2133HC11ADC01)
- KFA2 GeForce GTX 780 EX OC 3072MB PCI-Express Graphics Card (78XNH5DN8MSU) with FREE GPU Keyring
- No Graphics Card Upgrade
- No Graphics Card
- Samsung 512GB SSD 840 PRO SATA 6Gb/s Basic - (MZ-7PD512BW)
- Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD
- Pioneer BDC-207DBK 8x BluRay ROM / DVDRW SATA-II Optical Drive - Black (OEM)
- Seasonic 1000w '80 Plus Platinum' Modular Power Supply
- Microsoft Windows 8 Pro 64-Bit DVD - OEM (FQC-05955)
- BitFenix Alchemy Premium Modding LED Strip - Connect Red 60cm
- Networking Not Selected
- Keyboard Not Selected
- Mouse Not Selected
- System Build Fan - Noiseblocker BlackSilent Pro Fan PLPS - 120mm PWM [EXNO-001]
- Monitor Not Selected
- Speakers Not Selected
- No Headset Option (Zero Cost)
- Game Controller Not Selected
- No Office Software
- No Security Software
Well you picked the right time to start looking at a new build lots of new stuff coming out in the next few weeks.
With Watercooling, did you want an AIO prebuilt system like the Corsair H series stuff, or did you want a custom "kit"?
Any size constraints on the case?
Hiya and welcome to the forums, are you happy to build the machine yourself?
If possible get it built before delivery
Ideally pre built but get the OC people to build it prior to delivery.
No real size constraints on the case.
