£2000 Max Sandy build
16 Nov 2008
West Sussex
Ok so i now have my funds for a sandy build cant decide on what to go for GPU wise and whether to get sli/xfire instead of a single gpu. anyone able to help me plz. need monitor aswell. i got w7 mouse keyboard speakers. i have 750w psu if thats man enough for 2 6970/570?
ame Qty Price Line Total
Dell UltraSharp U2410 24" Widescreen LCD Monitor - Midnight Grey (3yr On-Site Warranty) £455.99
(£379.99) £455.99
(£379.99)
Gainward GeForce GTX 580 "GOOD Edition" 1536MB GDDR5 PCI-Express Graphics Card £383.99
(£319.99) £767.98
(£639.98)
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - OEM £239.99
(£199.99) £239.99
(£199.99)
Asus P8P67 PRO Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) £137.99
(£114.99) £137.99
(£114.99)
Crucial RealSSD C300 64GB 2.5" SATA 6Gb/s Solid State Hard Drive (CTFDDAC064MAG-1G1) £91.19
(£75.99) £91.19
(£75.99)
GeIL 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Dual Channel (GVP38GB1600C9DC) £85.99
(£71.66) £85.99
(£71.66)
Coolermaster CM-690 II Advanced Dominator Case - Black £72.98
(£60.82) £72.98
(£60.82)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £39.98
(£33.32) £39.98
(£33.32)
Akasa AK-CCX-4002HP Venom CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM3) £35.99
(£29.99) £35.99
(£29.99)
Sub Total : £1,606.73
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £22.20
VAT is being charged at 20.00% VAT : £325.79
Total : £1,954.72
Almost forgot: http://www.overclockers.co.uk/showproduct.php?prodid=HS-059-AK&groupid=701&catid=14&subcat=72
i have this so far cant decide on case and gpu or gpu configiration. and is 750w psu enough for 2 gpu's or need more?
RJC's build except:
http://www.overclockers.co.uk/showproduct.php?prodid=BU-013-OP&groupid=701&catid=6&subcat=1858
That bundle instead of his suggested CPU/Mobo, exactly the same just cheaper :)
http://www.overclockers.co.uk/showproduct.php?prodid=CA-212-CM&groupid=701&catid=7&subcat=29
That case instead of the advanced version,
and with the money I've saved you can get the blu-ray drive he forgot ;p
As for advice on your ideas so far... Don't get the H70, it's not that good.... So not worth the money if you really want to spend that money on a cooler get a Noctua D14, however the Akasa RJC suggested is fine.
RAM - Get the Geil stuff, or the OCZ Special ops stuff - both are fine.
Your PUS should be fine for 2 GPU's....
Cases: Well looking around £60:
First is there anything wrong with your current 1200?
Otherwise depending on what you want I'd say,
CM 690 ii
CM HAF 912
Fractal R3
kd
nothing wrong with my 1200 but im anal and want it all new :) lol. is it worth getting 2 gpu for 1920x1080? i see on p67 only x8 if running 2 or is that not much of a big deal?
There is only 2-5% difference between a full dual 16x and 8x boards, I use one 580 on the monitor speced, did have 2 580's but one is fine.
well was looking at either 2 570's or 2 6970/50 but cant decide lol. too many choices lol. BTW whats the difference with that lite case compared to the advanced version?
