£2000 Spec
4 Apr 2012
Hi everyone, I would appreciate if you guys could make me a computer spec for £2000 as said in the title, an os will not be needed and neither will the keyboard, mouse or monitor, just the system.
I do video editing/ Rendering
And intense gaming while running muliple programs
What do you guys think?
Edit: I would prefer if the corsair 600t was the case and it was colour
Coded blue :)
Hi!
One option is going down the Socket 2011 route with the E CPU.
YOUR BASKET
1 x Intel Core i7-3960X 3.30GHz (Sandybridge-E) Socket LGA2011 Processor - Retail £839.99
1 x KFA2 GeForce GTX 680 2048MB GDDR5 PCI-Express Graphics Card with FREE NVIDIA GPU Keyring £449.99
1 x Gigabyte X79-UD3 Intel X79 (Socket 2011) DDR3 Motherboard £179.99
1 x Corsair Graphite 600TM Midi Tower Mesh Windowed Case - Black £139.99
1 x Kingston HyperX Genesis 16GB (4x4GB) DDR3 PC3-17000C11 2133MHz Dual/Quad Channel Kit £119.99
1 x Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT128M4SSD2) £99.95
1 x Seagate Barracuda Green 2TB SATA 6Gb/s Hard Drive - OEM (ST2000DL003) £84.98
1 x Cooler Master Silent Pro Modular 700W '80 Plus Bronze' Power Supply £76.99
Total : £2,008.37 (includes shipping : £13.75).
Or
YOUR BASKET
2 x Gigabyte GeForce GTX 670 Windforce 3X 2048MB GDDR5 PCI-Express Graphics Card £371.99 (743.98)
1 x Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £268.99
1 x Gigabyte Z77X-UD5H Intel Z77 (Socket 1155) DDR3 Motherboard £173.99
2 x Kingston Blu 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (KHX1600C10D3B1K2/16G) £99.95 (199.9)
1 x Corsair Hydro H100 Extreme Performance Liquid CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3) (CWCH100) £85.98
2 x Seagate Barracuda Green 2TB SATA 6Gb/s Hard Drive - OEM (ST2000DL003) £84.98 (169.96)
2 x Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin £13.99 (27.98)
Total : £2,005.42 (includes shipping : £14.75).
Both builds are very capable of what you want them to do. Personally I would lean towards the second one as it's more aimed at games than the first.
They are quite flexible too. You can swap out the boards to make more budget for HDD space etc.
Also I should add that you don't 'need' to spend the whole budget but I prefer too :P. Others prefer to try and save pennies which is great so there should be some contrasting builds soon :)
Yea only £150 on he monitor I think since £300 is a lot for a monitor
Oh and 4Tb isn't necessary only 2tb and with the money saved from that maybe you could fit a 256gb SSd?
It's a shame there is no white RAM really. With that board inside the White Graphite it would have looked very nice. Prefer the white case over the black.
That looks great, however with the budget I have I should really get a gtx 680 in there, so I used the rest for a windforce 680
Yeah good choice. I managed to get it in earlier but as I said after swapping around it gives you the freedom to pick and choose where you want the budget swayed. :)
