2002 Corsa is it ****ed?
Breakdown cover really has nothing to do with the value of the car!?
When you're stuck in the middle of nowhere in the middle of winter freezing your arse off because it's broken down you'll be wishing you spent that £50 on cover, to be honest if you look around some cashback sites or check when you buy insurance they pretty much give it away.
I Doubt that would make it behave like its got a flat battery mind you....
More than likely not but the fuel pump when run dry can make an awful noise... If it's sat on a hill and low on fuel it might not be picking up the fuel...
It does sound like its the battery or alternator but just looking at other ideas...
