i texted a guy i know that works as a tech in dunton for development centre, despite the stuff in the reservoir being red and PAS fluid often being ATF, he was adamant it wasnt :S
Ford use a different spec than most other car makers and it isn't atf the only company I have found that make some to the right spec so far is millers oils and is called millermatic MDM.
I believe they use the same mineral oil based stuff as merc now, not entirely sure but its worth checking. we refilled a system wit hATf not realising the change and the pump constantly whined.
