Hi Guys
hope you can help
I have build a remote desktop farm using windows 2008R2 servers...all access is via the remote desktop web access installed on 2 server with simple dns round robin set (cert was issued for the https certificate from the CA from an IIS cert request)
one of these sever is also running the connection broker role that point to the 2 seperate farms...farm1 is 2 servers and farm2 is 3 servers (each farm running different applications etc.
all the above works published application start..But there so many warning messages and extra login boxes to run an app that it doing my head.
where I'm stuck is what cert(or GPO) I need and how I get it created, it also harder as I have very little access to the Domain, getting anything done is little more challenging....
so advice help guidance please...so I can speak the team that should be able to help have al the info and no reason to hold me up
thanks
hopeful you understand what needed...
GJUK
hope you can help
thanks
GJUK
