200mm for haf x
Ok my haf x is about 7 months old and the top far is starting to go. I am not surprised after finding out the idiots at CM use sleeve bearing fans for the the case. (sleeve bearing fans dont like to be mounted horizontally since the oil/grease sits at the bottom, so looking for a rifle bearing or ball bearing replacement)
Antec big boys are no go as would need to do some drilling/modding on them to get them to fit (i dont have the tools or want to have to mod).
Leaves me with rifle bearing or ball bearing replacements. Any recommendations?
