- 17 Apr 2010
Hi,
I have a CM Storm Trooper case, and am looking to replace the fan on the top, at full whack it's quite audible.
Apparently it's also possible to fit 2x 140mm fans, so am happy to consider this as well.
The CM Storm has an integrated fan controller on the front and it only seems to only take 3 pin fans, so PWM is not an option.
Suggestions?
Regards,
Chris.
Suggestions?
Regards,
Chris.
