Before reading COYS post I would have said CM Megaflow hands down, now firmly have my eye on one of those 230mm spectres (200mm hole spacing). 156cfm for 25dB, I'm sold
Any ETA on these yet?
Edit, found some places selling them on pre-order, £13 for the 200mm with a stock arrival date of 16th Jan. Can't wait to get my hands on one of those 230mm fans
Edit again, £14 for the 230mm.
Edit...Again...Found an etailer in the UK, they have stock of the 120, 140 and 230mm fans, just not the 200mm. 230mm is priced at nearly £19 with them! While another has stock of all of the sizes apart from 230mm, the 200mm coming in at £15. Common OCUK get some stock in!
definitely looking at the same place with the eta of 16 January. do you think the 230 will fit your case in the front? hoping it will fit my 600d but if not the 200mm looks a winner
Front of the 500R is 2 x 120mm only, though I have unlimited room where the side 200mm is, and as bitfenix are one of the few companies that make 200/230mm fans to a set standard of 154mm spacing.
With the fan rotated 90 degrees it may fit in a 650d/600T, as only one axis measures up at 230mm, the other side with flat edges is 200mm. On the links you posted click the 'support' tab and bitfenix are kind enough to put up full measurement specs of the 200/230mm fans
Going to get one ordered tomorrow, not much in it between the 200 and 230mm, about 8cfm and 2dB for the better in the 230mm. Still blows away the next best thing (megaflow) which is iirc 110cfm for ~20dB
2 well know major UK etailers have stock of the Pro fans too, so don't bother with the ETA 16th place
Again....OCUK get some stock!!! Surprising lack of 200mm+ fans on offer.
nice one, found the blue 200mm in stock thanks. Not sure if the 230mm will fit the front of my 650D so will order a 200mm and move my Megaflow to the top of the case for now.
