2014 Honda CR-V, odd noise from behind dashboard
1 Jul 2011
I have been hearing intermittent strange clicking/fluttering type noises from somewhere behind the dashboard when the engine is running and also when stopped, but only with the ignition switched on, I thought it was an air lock bubbling at first but it stops with the ignition off.
I came across this post which seems to cover a similar problem
https://www.driveaccord.net/threads...sound-under-dashboard-steering-column.112881/
This concerns an 04 Accord and I wonder if I have the same problem, if so where would this component be in my car. There are two links to recordings in the topic which sound similar to what I am getting, I can only hear it inside the car, not outside.
My A/C system seems to be working ok otherwise.
Has anyone else had this with a Honda or any other ideas
Thanks
