2070 super Temps
16 Oct 2018
Hi
I've just got a Gigabyte Aorus 2070 super. The temps are 35 degrees in Windows. When running PUBG its 70 in the lobby and in game going up to 85. Is that normal?
I'm using a a Coolermaster Cosmos S case and can add two additional case fans (80mm I think) to the top of the case which may help with the cooling.
Cheers
S
Hi
Cheers
S
Sounds quite high to me, can you hear the fans ramping up when you're hitting those temps?
I think first of all I need to check to see if I have pwm or dc fans. The motherboards has, I believe 4 pin connectors (ASUS sabertooth x99). I did go into the BIOS and change all fans from the standard setting to Turbo mode. The top of the case was warming up and this seemed to have stopped that. I think I'll change the 90mm stock case fan and add a couple more to the top of the case to see if that helps.
Cheers
