2080ti - Black Blinking Screen and Horizontal Flickering Lines
26 Aug 2009
So after some time of use, my screen goes black and comes back.
When I can see the desktop I might get the odd flicker of a horizontal line, sometimes a thick line of noise.
It was particularly bad just now, so I opened up heavens benchmark - graphics card was about 50c, and the black screen was frequent (every few seconds)
Once I restart the PC it clears.
GPU Ram problem? or something else.
it's been like this for a few months, but I just restarted the PC to clear it.
Did you try another cable I had one go bad on me,lucky I had a spare.
The card may not be seated correctly,or even a driver problem.
Cable breaking down most likely, like clone says. What monitor is it hooked up to and what connections HDMI, DP.
It being horizontal shouldn't make a difference, unless it's sagging badly which means it could need reseating in it's PCI-E slot.
