So I have a 2080ti - and occasionally the screen goes black and GPU fans go to max. I have to disconnect and hold down power button for a good 20-30 seconds before I can get it to boot back up.
I'm typically running a windowed game and doing something else, like browsing internet or processing photos in lightroom. GPU is not OC, Ryzen 9 3900X OC to 4.3ghz
Concerned it's a GPU fault I tried Furmark which runs fine, GPU+fans work harder than my typical loads - temperatures fine.
Any thoughts about how to diagnose it further?
I was using the GPU support bar but thought perhaps I should mount the card vertically, so that it doesn't suffer under it's own weight.x
It's a Phanteks P600S case, it has a vertical GPU mount but no riser cable, so I was looking at the Lian-Li and had a question about that.
Will the Lian-Li or another version 4.0 fit ok, the screws are standard?
https://www.overclockers.co.uk/lian-li-pcie4.0-gpu-riser-card-cable-20cm-ca-78u-ll.html
as the Phanteks own version is 3.0
https://www.overclockers.co.uk/phan...-riser-cable-90-degree-adapter-cm-02p-pt.html
