2080ti Ftw3 blocks
I just checked and EK's cooling configurator just says coming soon. What about the Chinese blocks, Bykski or something similar? The blocks look good and seem to be of a high quality. Quite a few people on here seem happy with them plus they tend to make blocks for cards that other manufacturers don't bother with. The downside is that you have to order from China.
Ok thanks I’ll check it out!
It’s quite annoying because the evga do the hydro copper blocks for the card on their US site but don’t deliver here!
And the one on the bay was £345 so that’s out of the question!
You are better off dropping a quick email to EK direct as usually they will tell you roughly when they expect it to be available. They usually reply within 24hrs too.
Used to have a representative on the forums although I haven’t seen him active as of recent.
@EK Luc
