hi
am a little confused with m.2 drives with regard to pcie lanes for gfx card.
Have an Asus z370-prime motherboard with a 500gb m.2 at top of motherboard and a Sabrent m.2 drive at lower part of motherboard. I have read that the lower Sabrent drive stops the use of one of sata ports.
My 2080 is in the upper pciex16 slot on the motherboard.
Is the gfx card sharing lanes with the m.2 at top and if so why is the bottom one connected to the sata ports? Gpu-z reports the 2080 as only using pciex8.
Am quite confused - how do I run my 2080 in pciex16 and use both my drives?
I also have a problem, quite often win10 will be in an awful low res when boot up and initially nzxt see's no display device but after a min or so the screen will go black before screen returns and in native 2560x1440p res. Anything I can do to fix?
Many thanks for help, much appreciate.
