- 8 Sep 2018
I noticed a small difference between two of the GeForce RTX 2080Ti for pre-order and I was wondering if anyone could clarify this seemingly insignificant difference, or if it means more - enough to warrant noticing...
Number One:
GEFORCE RTX 2080TI DUAL OC 11264MB GDDR6 PCI-EXPRESS
Manufacturer Part Code DUAL-RTX2080TI-O11G
Graphics Engine Nvidia GeForce RTX 2080 Ti
Number Two:
GEFORCE RTX 2080TI ICHILL BLACK HYBRID 11264MB GDDR6 PCI-EXPRESS GRAPHICS CARD
The Fastest, Most Brutal Turing Card To Date!
Manufacturer Part Code C208TB-11D6X-11500004
Number One mentions 'Dual OC' - is this an indication of the number of fans or something more?
Number Two appears to be a self-contained water-cooled card. Does this have any implications on performance or any other difference between the other card and other cards.
Alternatively, is there a superior card to these that is on pre-order or slated for near future release?
Thank you!
Number One:
Number Two:
Thank you!
