2080Ti Micro Stutter, any help appreciated
6 May 2015
North London
Hi Guys
I purchased a Gigabyte Aorus 2080ti Waterforce from Overclockers last Friday(great service by overclockers as usual) and what i am finding i am getting is micro stutter, just random jerky stops for not even a second and its getting really annoying.
I was trying out Watchdogs 1 last night and this was happening maybe every few minutes or so , even when i tried heaven benchmark it would micro stutter as well, even though i would have MSI afterburner and Riva tuner running and they would be showing 80-90 FPS.
i uninstalled the Nvidia drivers and used DDU to completely remove the drivers , then freshly installed the new drivers and the issue still occurs.
if worse comes to the worse ill RMA it
I know you guys on this forum know your stuff , so could anyone give me advice how to solve this issue ?
(also i am at work and i am currently getting GTA 5 and FF15 installed so i can test when i get home)
Ya sorry , off the top of my head
a 8700k ( no overclock )
16gb of corsair ram 3000mhz ( XMP ON)
MSI 1151 motherboard
samsung 500GB SSd - and 250gb NVME
Platinum EVGA power supply - ( off top of my head i cant remember exact wattage sorry , i believe its 750watts , ill update this later when i get home )
Windows 10
Acer x27 predator
Gsync on , i run my system at 98hz , i have tried VSync on and OFF in the Nvidia Control panel , ive also tried full screen and in window whilst testing.
hopefully they will help . any thing else you need to know please ask , ill try my best to answer but as i said i am at work at the moment.
You mention using afterburner and rivatuner, I had a very similar stuttering when using gpu tweak 2's OSD to display frame rate etc. Turned it off and no stuttering
