Morning all !
I couldn't find a thread specifically about overclocking this card so thought I'd start one having received my Palit 2080Ti OC from OcUK over the weekend: https://www.overclockers.co.uk/pali...ddr6-pci-express-graphics-card-gx-04b-pl.html
Not a great start as it didn't want to play nicely with a secondary display but after swapping around DP cables in the back of the card got both my PG348Q and AOC G2460PQU working at full resolution & refresh rates.
Once that was sorted, fired up the latest beta of MSI afterburner as per this overclocking guide and ran the OC Scanner test. That found an average OC of 163Mhz on the core, not bad, however... furmark is giving hard resets when doing anything other than a stock clock stress test. Even at stock clocks but with power limits raised the machine hard reboots. First thought given no BSOD was power issue but the PSU is (seemingly) rock solid - Corsair HX850i and when running AIDA CPU stress test and Furmark the reported wattage is still below 500W. Example 'screenshot' showing all stats here (I had to take a photo as triggering the screen-snip overlay in W10 was enough to trip the fault). This is how the GPU is installed: split 2x8-pin connectors off the PSU.
Prior to GPU upgrade I was running an overclocked 1080Ti and 7700k @ 5Ghz, rock solid stability wise.
Anyone had any other experiences on this?
Cheers
dvs
Cheers
dvs
