FTW3 when benching and fans turned up the temps stay below 60C most of the time.
Clearly better cooling on the FTW3 i gather but am i ok with the temps i am getting?
You mean fans all the way up ? Like 100%?FTW3 when benching and fans turned up the temps stay below 60C most of the time.
Would you be able to keep it on 60% and tell me what temps you will get with that please ?
thanks for mega massive screenshotWill do some tests later when I am using them.
Any chance to try them just with for example 60% fan ...? Just want to know how its perform if fan is not to loud.. Thanksthanks for mega massive screenshotAny chance to try them just with for example 60% fan ...? Just want to know how its perform if fan is not to loud.. Thanks
FTW3 2080 Ti SLI
Heaven 4 max settings @2160p
Fans locked @60%
After 35mins looping
Temps in top right hand corner.
One card slightly warmer, one card the same.
The one above is at 60% on the fans.![]()
Beautiful work you are my man ! Thanks
