2140 + oc mobo -or- 4500 + non-oc mobo?
Caporegime
17 Feb 2006
Cornwall
Heya :)
First off, this isn't a PC for myself, it's for my niece to play her horsie games on. The current machine she has doesn't have a GFX card, and her mum wants to buy a whole new PC. Therefore, upgrading options have been ruled out :)
The dilemma I'm having is between CPU and mobo (and possibly RAM, were it not so cheap anyhow).
A 2140 can be had for £40, and a decent mobo (Giga P35-DS3) for £70. That would have course be the overclocking route. A possible 2.5-3 ghz machine for £110.
However, a 4500 can be had for £75, and a cheap ECS mobo for as little as £25. That's a 2.2ghz machine for £100.
At a stretch, the 4500 + decent non-oc mobo is possible, if not costing more than £125 ish. That's assuming that there is a difference in quality/ stability between a £25 and a £50 mobo.
Whilst we're not talking about a machine to play Crysis, I will also be upgrading my own PC in the near future, so discussions of relative Crysis performance are valid ;)
At the end of the day, I'd like to know which route is better - the oc route or the better CPU route. And whether a cheap mobo would be suicide or a good move. Doesn't need on-board VGA, of course, since I've budgeted £70 for that already.
e2180 and abit ip35-e then overclock it to as high as possible.
run a few hours of orthos to test stability first and if yoru niece needs an intel quad you can just get her one to put in along with a nice high end GPU.
a good mb would be my choice and will most likely be made of better components anyway
2140+good mobo (OC or not)+leave everything at stock! Sorry, I don't see the reason why you want to OC :confused: It will cause stability problems & you know that you'll be their technical support 24/7/365! Other factors are the components will wear out faster, higher power consumption, etc.
@ stock, the E2140 is no slouch!
I think if you get a E2160, it will go to 3.0Ghz REALLY easy without much stressing the components on that Gigabyte P35 motherboard.
it will run at this:
CPU: 9x333 = 3.0Ghz (standard voltcore possible most of the time, not REALLY stressing the cpu)
Motherboard FSB: 333x4 = 1333Mhz (Supported by the motherboard, not stressed)
RAM: 333x2.40=800Mhz~ (standard supported by PC6400, not stressed)
Fast/Reliable overclocked PC for almost no money ;)
As for what hp7909 said, I don't agree that it WILL cause stability problems. If you don't go to far there should be no problems at all. Anyway, that 4500 @ 2.2Ghz. The E2140/E2160/E2180 will do that blindfolded ;)
I've never been happier with my E2160 then any processor I've had.
I'd always get the best motherboard I can afford, and the e21x0 series are very good. As for whether you should overclock when you build for a n00b, then thats up to you.
Saying that, n00bs can get into plenty of problems that have nothing to do with the overclock!:D
I recently did a build with the E2140 and chose to invest in a decent motherboard (think i paid near £100 for one). At the end of the day, the motherboard is going to be the main foundation your pc is built on, so you want it to last, and i tend to go by the "you get what you pay for" theory/motto/whatever you wish to call it.
But yeah i would go the Intel route, with a decent P35 chipset motherboard.
