- 6 Jun 2007
I am currently undecided on which one to buy between these two LG models.
LG L204WT 20" Widescreen
- Viewable Area: 20” Widescreen (1680x1050 Resolution)
- Response Time: 5ms
- Contrast Ratio: 2000:1
- £170.36 inc VAT
LG L226WTQ 22" Widescreen
- Viewable Area: 22” Widescreen (1680x1050 Resolution)
- Response Time: 2ms
- Contrast Ratio: 3000:1
- £211.49 inc VAT
The differences are contrast ratio and response time. My dilemma is this, if they have the identical native resolution which one would look best given one being 20" and the other 22"?
Also could you please confirm if a BFG GeForce 8800 GTS OC2 640MB would be more the capable of handling such resolutions? I did some research and it seems so in reviews, they usually suggest get the 320MB version for resolutions up to 1440x900 and the 640MB for 1680x1050, but I am asking here since you folks have real life experience with such setups and would be definately better then just benchmarks/reviews found online.
Thanks in advance for your help and explanations and most importantly your suggestions.
Regards,
HD77
- £170.36 inc VAT
- £211.49 inc VAT
Regards,
HD77
