- 14 Jan 2009
Hi all, I am sure this has probably been covered before, but i can't find it
I have just Bought a 220mm case fan for my new case to fit in the side panel.
To me it seems to not flow much air, i have only tested it on my old pc at the moment, not actually fitted, just plugged in and holding in my hand. the 120mm in my current pc seems to have a much greater airflow ?
Is there a way to increase the speed on the 220mm fan without spenging huge wedges of money, thus creating a great airflow ?
specs below
Application PC Case fan
Frame dimension 220x30mm (170mm fittings)
Fan speed 600 RPM
Fan airflow 95.63 CFM
Fan life expectancy 30.000/hrs
Bearing type Sleeve Bearing
Connector 4-pin PSU Molex connector
Voltage rating 12V
Noise level 23 dB(A)
Product code AK-F2230SM-CB
specs below
Fan speed 600 RPM
Voltage rating 12V
