23" MAX DISPLAY - VESA
8 Mar 2013
I'm looking for a new display, but it must fit on my wall in quite a tight position! I have a bracket I'd like to continue to use (VESA 100, etc) and the monitor must be no wider than 680mm.
Do most modern LCD displays not cater for VESA?
My budget is quite low, it's only for light gaming. Perhaps £150 max. Doesn't need to be brand new.
Please advise!
I think DanHamman thinks monitor sizes are calculated by width. If he has 680mm of horizontal space to play with, then it's plenty of room. 30" monitors aren't even 680mm wide.
