- 8 Jun 2012
Heya,
I have decided to upgrade my current nas setup and try and shift my various different nas devices into a single unit. After a lot of searching for cases and solutions I have come up with a few different options and am having a hard time deciding which to go for. I was hoping some more experienced people with server/nas setups could have a look and give some advice. (prices are rough as not everything can be gotten on OCuk)
The case options:
24 bay 4U hotswap case with SAS 6Gb/s backplane (6x SAS ports) @ £300
24 bay 4U hotswap case with SAS 6Gb/s backplane and built in SAS expander (2x SAS ports) @ £700
Mobo, Ram & CPU options:
Supermicro X11SSH-CTF, 2x10Gbe and 8 port SAS onboard @ £450
Xeon E3 1240 v6 @ £270
Samsung 16GB DDR4 ECC Unbuffered (single stick) @ £160
Or I use my currently unused i7-2600k, MSI Z68 and 16GB DDR3 I already have @ Free
The next part I am a bit more unclear about what the best course of action is. The HBA/SAS side.
The supermicro board has 8-port SAS so if I get the case with the SAS expander afaik I would need nothing else (other than cables ofc).
If however I use my old sandybridge stuff, the case without SAS expander or go for something like a Supermicro X10SDV-2C-TLN2F, then I would need either 3x 8-port HBA, or a 24-port HBA.
Btw, the advantage to the case without the SAS expander (aside from cost) is that it is 10cm shorter.
For the HBA cards it seems I am looking at around this:
24-port (broadcom 9305 maybe) HBA @ £620
8-port HBA @200ish
Another big question is bottlenecks, with 24x sata3 drives will using, say, 6Gb/s SAS expander and an 8pport PCIE 2.0 x8 HBA give the same read/write performance as using 3x 8-port PCIE 3.0 x8 HBA and no expander, or a single 24-port PCIE 3.0 x8 HBA?
Is it worth looking at 12Gb/s SAS expanders and HBAs or will that make no difference with mechanical drives?
Ideally I am looking for a little future proofing, hence opting for the mobos with 10gbe if I am going to buy a new one, and I may well buy SAS drives in the future also however atmo all my drives are sata3, mostly nas drives.
In terms of software, that will be decided later but will most likely be one either unraid, freenas or xpenology, maybe esxi instead of baremetal for the last two.
Any help or advice would be greatly appreciated, I am a somewhat experienced system builder but have never dealt with SAS or server grade builds before.
The case options:
8-port HBA @200ish
