24" Display - Can you recommend
4 Mar 2003
Chatteris
OK, looking for a new 24" panel. A few requirements are:
1920x1200 (Not 1920x1080)
HDMI
DVI-D
VGA
DisplayPort
Height-adjustable would be nice.
Fast response rate as both games and other high-speed graphics will need to be shown.
Price:
I cannot say money is no object, however I'd love some recommendations across the board from the lower to upper ends.
Personal experience/recommendations are always best, but if all the reviews for a certain panel are positive I'd be interested.
Thanks.
Did you even read the post?
Op for your requirements there is no lower/mid/upper ends. Your requirements mean it will be top-end.
Without HDMI
http://www.overclockers.co.uk/showproduct.php?prodid=MO-052-DE&groupid=17&catid=510&subcat=
With HDMI
http://www.overclockers.co.uk/showproduct.php?prodid=MO-036-DE&groupid=17&catid=510&subcat=
1920x1200 is quite uncommon for monitors these days unfortunately. The Ultrasharps use IPS panels so the colours look amazing however there may be some ghosting in games. If you want best gaming response you need a TN panelled monitor which will only come at 1920x1080 resolution. you need to decide which trade-offs are acceptable to you.
