Hi guys,
I'm living in a fairly large dorm room and hoping to buy a new monitor to play my playstation 3 on. I've seen a lot of suggestions and found it all a bit confusing. Only other use other than the PS3 is I'll get a cable to run from my macbook to show movies on, it won't see normal monitor use.
So far I've torn between the Samsung P2450H and the BenQ EW2420 (and maybe the LG W2442PE? I'd like the monitor to passthrough audio so I can use a HDMI cable and run my speakers through the audio out 3.5mm jack.
The samsung seems a little expensive for what it is, since it's the same as the other 24" on offer but just the popular model - the Benq is curious since it has nicer viewing angles and colours but.. a bit nervous about the ghosting. My previous monitor was a Dell 2407wfp which wasn't the fastest either, anyone had any experience with them both?
Anyone been in a similar situation and can give me some advice please?
Cheers!
Cheers!
Really need to decide.. I guess the benq's out and it's not on special anymore anyway.
