Hi Overclockers,
Hope you all had a great day yesterday and got what you wanted from Santa
I need a bit of help with a choice on 24" gaming monitors. I'm a bit tight for space to fit 2 monitors in so I'm looking a 2 skinny bezel models (see below) can anyone recommend one or the other to be used mostly for gaming ?
http://www.overclockers.co.uk/showproduct.php?prodid=MO-097-IY&groupid=17&catid=510&subcat=
and
http://www.overclockers.co.uk/showproduct.php?prodid=MO-050-AS&groupid=17&catid=510&subcat=
Cheers, Fluffybob
I need a bit of help with a choice on 24" gaming monitors. I'm a bit tight for space to fit 2 monitors in so I'm looking a 2 skinny bezel models (see below) can anyone recommend one or the other to be used mostly for gaming ?http://www.overclockers.co.uk/showproduct.php?prodid=MO-097-IY&groupid=17&catid=510&subcat=
and
Cheers, Fluffybob
plus it says 1ms which may or not be true
