- 11 Mar 2008
I'm looking at adding a 3rd monitor to my setup (currently have 2 1920x1200 24" monitors). Will be using this for software dev, general desktop use and some gaming (have an AMD 7990, so looking at Eyefinity for some of the games).
I also have a wall mounted TV above my desk, so have made some measurements and it looks like I would not be able to fit a 27" monitor as it would overlap the bottom of the TV screen, so 24" is the biggest I can currently fit
My initial thought is to get another 1920x1200, with both Asus and Dell offering good monitors (looking for IPS or equivalent), however from what I can tell the options available are all a few years old - do any companies have any new 1920x1200 monitors on the horizon? I'm guessing the answer is no since the focus now seems to be on the 16:9 options, I'm getting the impression that 16:10 is a dead ratio
Had considered Dell's 24" UP2414Q UHD monitor, looks nice and the high res would be good for software dev, however from what I have seen the reviews for it are fairly average. So think I might be better off waiting for the 2nd generation of this monitor.
As I might get a UHD screen when the next geration of them come around, I don't want to spend too much just now (my oldest monitor is one of the OCuk DGM VA panels from 2007 (I think) and that appears to be starting to struggle now, with some obvious ghosting that didn't used to be there, suspect this may not have much more life left in it!), so my options appear to be one of these two:
Asus VS24AHL 24.1" Widescreen Professional/Gaming LED Monitor - Black
http://www.overclockers.co.uk/showproduct.php?prodid=MO-068-AS
Dell UltraSharp U2412M 24" Widescreen LED Monitor - Midnight Grey
http://www.overclockers.co.uk/showproduct.php?prodid=MO-052-DE
or are there any other options I've not considered?
