24" Monitor?
22 May 2009
Hi. I'm considering getting either a ViewSonic VX2453MH-LED or a Iiyama Pro Lite 24" E2409HDS/E2407HDS.
Which would you say is better between these or are they all pretty similar?
Also not too sure what the difference is between the 2407 and 2409 Iiyama's?
I was also wanting to use the monitor as a bedroom tv to watch the odd movie (blu ray or dvd) and also for hooking up a console and watching tv besides using for my desktop. I am guessing that these should all be DHCP (?) certified and able to be used to watch tv/movies/play games if I hook up sky box, blu ray player, games console etc?
Thanks very much for your advice,
John
