Hi guys i am looking to raise the height of my 24 pin ATX power socket so i dont have to use low profile memory.
I use a PICO psu and when using tall ram it gets in the way but if i can raise the 24 pin ATX socket the issue is solved does anyone know of 24 pin atx plug you can plug into the exsisting 24 pin plug to raise it up ?
Thanks
Thanks
