24 pin
16 Sep 2005
Please answer waiting to power up 24 pin
Quick question Just putting together my new system :)
My first intel Do i need to connect all 24 pins from the powersupply as well as the 4 pin atx.
only on my other buillds amd only used 20 pins + 4 pin atx cabble
Gigebyte ds3
Enermax liberty 500w
thanks
Welcome to the forums. :)
I know on AMD boards that a 24-pin motherboard will work with only a 20-pin plugged in, not sure about Intel though, although i can't see why not, if it hasn't got enough power with just a 20-pin though it will probably just not boot, or it may boot but be unstable. :)
