24 port switch recommendations
18 Oct 2002
Hi,
Just getting some gear for home network. Just the switch left to buy. Not currently using any POE equipment and do not currently intend to, so does anyone have any good recommendations for a reliable quiet switch?
Cheers
You can pretty much buy anything with those requirements, main thing currently will be selecting something that isn't out of stock
TP-Link for sure, I have the 16port version and it has been excellent. Build quality is up there with the big boys too.
It is literally impossible to buy a bad unmanaged non PoE gigabit switch in this day and age. In rack mount terms they usually all have a metal chassis anyway and will all perform similarly, you can get semi-managed switches if you want some level of additional control without full management.
