- 7 Jul 2008
- Newcastle upon Tyne
Which has the thinnest bezel
I did actually edit my origional post as this is what I have noticed, thin bezel but then a border on the screen.A thin bezel is nice but the actual lcd panel will still have a black border around it![]()
IIyama site is quite good as it tells you the viewable area and the screen size ie Viewable area width = 527mm and the screen width is 539mm. Therefore 6mm each side?
PS this is a project for tripple screen setup for a racing sim, hence the question about bezel thickness..
Also, am I correct in thinking that a 1ms TN panel will be better than a 6ms IPS panel?
So are you looking for 1080p/144hz monitors with thin bezels? Or will 60hz doI have a 34 ultrawide and the triples are much better
