24" VA monitor busted - any recommendations for a replacement?
28 Jan 2007
London
SadSmiley.svg
So my replacement for this monitor I originally bought almost 4 years ago has also gone kaput, and it's virtually impossible to find any of these around now.
http://forums.overclockers.co.uk/showthread.php?t=17806175
Things I loved about this monitor:
+ VA Panel
+ 16.7m colours
+ 180/180 viewing angle
+ 1920x1200 resolution (WUXGA)
Does anyone have recommendations for a cheap replacement preferably to the above spec or similar?
Tanks.
Thanks for the suggestion beefybarn, that does seem a good 24" VA panel. However I've since decided to move away from my desk and get a Macbook Pro, so meanwhile I'm just going for a cheap monitor replacement.
I was about to grab this OcUK V-Line 221V2SB 22" Widescreen LCD Monitor for £100, but then I noticed this IIyama Prolite E2273HDS 22" Widescreen LED Monitor for £140, which looks a lot better and also has 1 x HDMI input (so I could use the monitor elsewhere in the house once I get my Macbook Pro). Can anyone comment on the quality of the E2273HDS? Any other monitors below £150 that would be better?
