2407 A03 Ghosting
16 Apr 2007
UK
Hey all,
I brought my 2407 (Revision 03) about April-May this year and before now I have had no problems with it.
However, today I booted up my PC, opened up World of Warcraft and noticed the image was slower and sluggish - as if I was seeing it in slow motion - but only just noticeable.
I know there are ghosting issues that people have had with the 2407 - but I haven't heard about ghosting issues that just develop - is this common?
I checked the refresh rate and it was at 59 - there were two options 59 or 60 - so I changed it to 60 - I could have swore I had it on 75 or something - could this be the problem?
Thanks,
Marky
Nah it def won't be that you had it on 75hz before as this wouldn't work on this monitor.
Sounds like an rma job tbh:(
Although, it does seem odd that it should develop over time :(
You brought it? Where from and can I have one? :p
Would be odd if you were getting ghosting this far down the line, you wouldn't have had your screen at 75Hz as these screens don't support 75Hz, it's 60Hz max.
Did you change anything before you last shut down? Like a change of driver or something?
For some reason it's sorted itself out after a restart =\ Really odd :p
By the way kyle, I got it brand new from the auction site
