240mm computer fan source?
9 Dec 2006
@ManCave
Hi
im looking for a 240mm computer fan does anyone know of a manufacturer that does one?
my corsair side mesh supports 4x120mmso i thought instead of 4x120mm i could get 1x240mm instead :)
I'm not entirely sure if that would fit? Due to the fact that 2x120mm fans will have a space in between and also the 'middle' screws would need to be on top of each other? Kinda hard to explain without a picture...someone might prove me wrong though
here is a picture of the mesh in question was just going to use the 4 outer screws on each corner
true though i could make extra holes i was planning to use a 200mm i already have & make holes but you are right. possibly.
yeah I think a 240mm fan would come up slightly short however I had a quick search and couldnt find a 240mm one anyway! good luck though it'll look immense and shift some serious air if you manage it :cool:
well the idea is
Currently got
200MM pushing 108CFM intake at front 18DB
200MM pushing 90CFM outtake at top 21DB
120MM pushing 40CFM outake 18DB
Plan on doing
240MM pushing 1XXCFM intake
this should cool my 2x570gtxs down a bit!
Wow thats a great temp drop :/, mine suffering at the moment due to coolermasters idea of stock fans, silent but don't really turn I think they are 500rpm or so. Guess that 23cm fan is silent haha. Good job, looks sweet.
at 9V rather than 12V yes it is!.
Config now
230MM Pushing 150CFM Intake at side 21DB
Config now
Lol your case must be huge!! Gonna take a look. :D
