Decided I fancy going down the watercooling route...
I stumbled across a company which does an intergrated rad/pump/res,
This seems so much noob friendlier compared to most kits!
Anyway - I'm looking at cooling the CPU ( 3820 ) and a 7970, with the view of in the future adding another 7970...
Would I be best going for a 240mm, or a 360mm? and is there much of a difference temp wise?
I have the nzxt 410, which only officially supports 240, 360 would req modding & loads of effort but is the extra 120mm needed really?
Thanks a lot
Thanks a lot
