240mm rad placement.
9 Jul 2018
Blackpool
I have the corsair 500 RGB SE on pre order at the moment and the Asus Rog Ryuo 240mm ( waits for the hate)
The question is the radiator mounting position. If i front mount the rad is it best for it to use fans 2&3 ( counting the front base fan as 1 ) thus letting the lowest fan suck cold air into the case? or..
Top mount the rad? i would like to use two of the LL120's RGB fans and the original fans on the rad ( because i can ) - only thing is im not sure if i would get the height away from the motherboard after adding another 25mm? of thickness..
Thanks in advance.
Best to measure the case - I often find cases that claim top radiator support actually don't have any room for RAM clearance at all. Even more possible with push/pull.
