2443BW Question & Suggestions
14 Apr 2009
Buying a 24"+ Monitor
First about the title, I decided to change what I wanted to ask but can't change the topic >.<
Hello, I'm wanting to buy a 24"+ monitor to last so I want great quality, DVI & VGA minimum (HDMI and component completely optional, I can live without them). 1:1 pixel mapping, 16:10 preferably but I'm not too fussed about going 16:9. 3 year warranty if possible, I will be using it mostly for my Wii (component to vga), PC gaming, and watching a lot of Anime. Occasionally a 360 through VGA/HDMI I'm not fussed which. My maximum spend is about £300, I don't want to go higher if possible and lower the better, I heard about the samsung SM2433/43BW but I heard they buzz a lot with lowered brightness (colours > brightness anyday) so unless you can reassure me then avoid if possible. Thanks a lot in advance.
Yeah I saw that and I think I'm really keen on it but I was wondering what would people recommend? The Viewsonic or a Samsung SM2494HM? They both really float my boat even though they're 16:9 and I really didn't think I'd want 16:9 but there you go :D. So anybody know anything about the samsung?
