24GB or 16GB?
18 Oct 2002
Overground, underground..
CPU - Athlon x4 860K
Memory DDR3
slot 1 - Kingston 8GB -PC310700 (667Mhz max)
slot 2 - Geil 8GB 0 PC3-10700 (currently 667Mhz, 800 Mhz max.)
slot 3 empty
slot 4 - Geil 8GB 0 PC3-10700 (currently 667Mhz, 800 Mhz max.)
Hardest task the computer does is ripping BR to mkv
Would I benfefit removing the Kingston memory?
Always use even number of DIMMs to have them work in double channel mode.
Video encoding involves constant moving of big amounts of data between CPU and memory and extra memory definitely won't help in that with halved memory bandwidth.
Though that weak CPU is no doubt the biggest bottleneck.
(even full four module CPU with double the hardware couldn't match 4 core Intel)
As others have said best way is to try it, personally I would prefer 24Gb at 667MHz to 16GB at 800MHz, but then I may have different usage to you.
What motherboard? Some boards can run Dual channel or a hybrid mode even with 3 dimms
Personally would stay with 24GB even if you can't use dual channel mode. Outside of synthetic benchmarks, the penalty for single channel is about 5% if that.
Tried 16GB @800Mhz.
PC showed minor increase in benchmarks, but overall my PC was a lot more sluggish ie delays when opening a new window. :(
I've gone back to 24GB :)
