4 Mar 2006 at 20:46 #1 joffy joffy Associate Joined 18 Oct 2002 Posts 1,364 Location UK Is it ok to plug a 24pin psu connection into a board thats only 20pin?
4 Mar 2006 at 20:49 #2 geiger geiger Soldato Joined 5 Oct 2004 Posts 2,677 Location Garrison, New Jersey Think thats fine, since the 4pin part can be seperated anyway
4 Mar 2006 at 23:56 #3 G00SE G00SE Associate Joined 24 Feb 2003 Posts 338 Location Doncaster joffy said: Is it ok to plug a 24pin psu connection into a board thats only 20pin? Click to expand... Yes.
5 Mar 2006 at 00:01 #4 quadboi quadboi Permabanned Joined 28 Feb 2006 Posts 1,604 Yes, will work perfectly the extra 4 pin is for the newer mobo's
5 Mar 2006 at 08:17 #5 joffy joffy Associate OP Joined 18 Oct 2002 Posts 1,364 Location UK geiger said: Think thats fine, since the 4pin part can be seperated anyway Click to expand... Ah cheers, don't think my psu connection splits, but maybe i wrong.
5 Mar 2006 at 10:46 #6 Siders77 Siders77 Associate Joined 5 Nov 2005 Posts 960 Location Yate, Bristol You should have something like this: The bit circled in red should slide off.
5 Mar 2006 at 13:21 #7 mc_bob mc_bob Permabanned Joined 29 Aug 2005 Posts 1,552 Location Reppin' up North London My PSU doesnt, most do though. Mines a ThermalTake 500Watt. MC_Bob
