PC was build 2-3 months ago but without case
look like this:
https://abload.de/img/tn_30232705_1021442289zpas.jpg
I want to build small mining case, which looks good, take less space, its silent and also will work as little heater at winter.
List of thing which was done:
- custom design of case for 12x gpu without i/o brackets - 35m spacers betwen them
- plexi was laser cut and aluminium cut and drill on manual lathe
- I have to buy 24 risers in total bcoz narrow008c are sold with thick usb cable which was not good for cable managment also have bigger bend radius, so i bought 008c and also 006 regular ones with thin usb cable so i can mix them and use 008c with thin cables
- custom lenght 8PIN from PSU to 4x 6pin riser cables for power
- custom lenght 6pin from PSU to 4pin EPS
- stock fans and i/o metal bracket from gpus was removed (8-9screws each) 100screws total (stock heatsink not intact
- custom laser cut mount for ssd
- ssd is powered from internal SSD pins with custom cable - internal 4pin(2pin use) to sata plug
- fan voltage regulator - LM2596 voltage regulator + 1 @ 5fan 4 pin splitter
TO DO LIST
- side panels
- shorter 24pin cable
Specs:
case: 3mm plexi + 10x10alu profiles - 234x228x476mm - 25,5 liter
fans: delta 92mm 0,6A each @ 8,5-9V
fan controller - LM2596
motherboard - chinese B250C BTC
cpu - pentium G4400
ram - 8gb corsair
ssd - intel 120gb
gpu - kfa2 gtx1050ti
risers - 008c narrow
psu - seasonic(LDLC) platnium 750W
power consumption from wall - 650W
look like this:
TO DO LIST
- side panels
Specs:
cpu - pentium G4400
ram - 8gb corsair
ssd - intel 120gb
