To be fair - its less than 1% difference. I thinks it would be fair to say that the difference is within the margin of error and in WOW the 2500K and 2600K are just as good as each other.
so really your paying £85 to get hyper threading is it really worth having when it comes to encoding ?
I still don't understand how it could be possible unless its an error but then why would they display it on AnandTech
It does give you better performance - have a look at this page.
Whether this extra performance is worth £85 to you - I suppose you have to be the judge of that yourself.
Our World of Warcraft benchmark is a manual FRAPS runthrough of a lightly populated server with no other player controlled characters around. The frame rates here are higher than you'd see in a real world scenario, but the relative comparison between CPUs is accurate.
We run on a Radeon HD 5870 at 1680 x 1050. We're using WoW's high quality defaults but with weather intensity turned down all the way.
29.1 seconds for the 2600k compared to 31.3 seconds for the 2500k hardly anything in it really. I dont think i can justify the extra £85 for 2.2 seconds.
Just wanted to add this so hopefully it will help determine the facts.
