Deleted member 2277
Deleted member 2277
Hi,
I have fitted a 2500K CPU in my MSI Z77A-GD65 motherboard and I am seeing how high it will overclock.
I currently have it at 4.7GHz @ 1.32 volts, Temp approx 69 deg on air. Prime 95 so far has been running for 2 hours. Is this good or bad result for this processor?
I have booted at 5GHz @ 1.35v but Prime 95 fails after a couple of minutes. I have increased the voltage to 1.4 but Prime still fails. I'm a bit nervous about going any higher.
If 4.7 is 100% stable I will try 4.8 next.
