Hi guys, I've got a problem when OCing my 2500k. I'm overclocking my 2500k to 4.5GHz. To get it stable I'm having to run at 1.31v, a little higher than I was expecting but my temps are fine. However, when I prime it the multiplier will fluctuate anywhere from x40 to x45. I've disabled speedstep and all C states in the bios, the chip is at 4.5GHz at anything up to 90% load. Anything higher, though and the muti fluctuates. I've tried giving the chip a bit more volts but if anything this makes it worse. The multi is more stable at lower volts but I get BSODs after a few minutes at anything <1.30v. Any ideas?
