2500k core speed
30 Sep 2008
surrey
I have just tonight got my new build up and running and before overclocking i ran prime 95 for half an hour to check all was ok . Got 50-57 C . Little hight but ok i suppose . What i was more confused about was cpu-z reporting 3411 mhz :confused:
Turbo Boost.
Stock speed 3.3GHz.
1 core fully stressed Turbo Boost = 3.7GHz
2 cores fully stressed Turbo Boost = 3.6GHz
3 cores fully stressed Turbo Boost = 3.5GHz
4 cores fully stressed Turbo Boost = 3.4GHz
Thanks. I'm in stupid mode , new that really ;).
My temps with a titan fenrir standard clock using prime 95 read in core temp after 30 mins are
core#0 50c
core#1 53c
core#2 58c
core#3 56c
bit hight i thought . Whats the concensus ????
Oh yeh ambient is 24 and im using a silverstone fortress so plenty of airflow ...
I have that temp with my stock cooler, about 57-60 fully stressed. Don't know why you say it's high? If it was something like 80-90 then you could be a bit worried.
I've got mine set as:
1 core fully stressed Turbo Boost = 4.5GHz
2 cores fully stressed Turbo Boost = 4.5GHz
3 cores fully stressed Turbo Boost = 4.3GHz
4 cores fully stressed Turbo Boost = 4.3GHz
Get high 60 degrees c on Prime 95 with stability.
im using a hyper 212 on my i5 2500k at stock, im getting temps in prime 95(after 2 hours) between 49-51,
not sure 100% sure on my ambient temps but cpuid is showing my hd assembly temp is 26,i think ambient is closer to 22-23,
gonna get some extra case fans and probbaly an akasa venom 120mm fan to stick on the hyper 212 for push/pull set up and then see how far i can OC.
Tbh i'm really impressed with the i5 even at stock, i went from pentium 4 to this :)
My case is haf 912 plus
If you just built the pc today the thermal paste might take time to cure, so temps might improve a bit over time,
My core #0 is always coldest and core #3 the hottest
imo the titan fenrir is crap, got one for my q6600 and it was useless temps were far too high (after a fair few resits/reapply thermal paste)
Are those temps read with coretemp ???
