Hi
Been a while since dabbled with overclocking but just fitted a Noctua D14 and thought i'd see if i could get stable 4.5 or 4.6. But no where near. At 4.3 the pc just shuts down after around 20 minutes prime 95. No bsod, just shuts down.
4.3 (42x103)
using 1.36v according to core temp
or 1.408v according to cpu-z ??
Highest temp at any stage was 64deg on core 4. Which does not seem that high...
This is via Asus 'performance' template in bios... didn't enter the values manually. Board is an Asus P8Z68-V
Where do i go from here?
4.3 (42x103)
. But still can't figure out how the voltage offset works. It's set to negative, if i change the cpu offset voltage from auto to 0.005 it will not even boot into windows. Confusing.
