2500k @ Stock IBT result?
Caporegime
18 Sep 2009
Dormanstown.
I'm wondering on whether or not my 2500k is degrading.
Can someone run IBT 2.52 using 4GB RAM @ stock on a 2500k for me please with a screenshot?
Cheers.
Don't have the chip but have been alerted just recently by other members about some IBT issues, unless you have windows 7 SP1 and ABX (I think its called? might be AGX) it won't make full use of your chip, so make sure these are installed first if your hitting low scores.
Oh, I know :p.
Hence why I want a user result.
Cool, just thought I'd clear that up before other 2500k owners ask, what scores are you getting btw?
Edit: and what settings are you using for IBT?
As I just wrote in a thread in CPU subforum...
The peak GFLOPS possible of a chip is only down to three things: the clock speed, the number of cores, and the instruction sets.
Example:
Your 2500K has 4 cores, is clocked at 3.3 GHz (say), and possesses AVX and you're using v2.52 on Win 7. The peak possible GFLOPS is then 4*3.3*8 = 105.6. (That 8 becomes a 4 without AVX.)
The more memory you use in IBT the closer you'll get to this value, but the longer each loop will take. Most likely you'll see it max out around 80%.
In summary, to stress test at stock (not sure why you would do this) you must use sufficient memory to get about 0.8*105.6 = 84.5 in the GFLOPS column.
So to help you with your question - I suspect that the GFLOPS reported by IBT is far more dependent on the memory usage than "degradation" in the chip, if it exists at all. "Degradation" is more likely to effect stable overclocks than computing power at stock, IMO, if it exists at all. 93 is perfectly fine.
