Hi guys, I've currently got a 2500k running at stock speeds. Recently I've been having trouble with BF4 with frame rate drops and CPU usage hitting 100% and being exceptionally high. I thought it was just Battlefield 4, but on a whim I decided to fire up some Battlefield 3 but started getting the same issue with ridiculously low frame rates.
I've been running on the stock cooler since I built this PC 2.5 years ago now with no issues, however I decided that perhaps something up with my CPU. I checked the temps on HW-Monitor and I was getting crazy temps like 97 degrees at max load. So, I'm not exactly sure if it's a dodgy sensor or not. I cleaned up the insides of the case and got rid of the dust clogging my CPU heatsink and booted up. The idle temps read around 46 now, but again when I to something CPU intensive it still goes up to the 97.
I fired up BF3 again and there were significant performance improvements. I'm not sure if it's all a coincidence or not and will be doing further testing but one of the sensors TMPIN1 even had a max of 119 degrees, so I'm suspecting something is up with my sensors. TMPIN0 reads the max of 97 though which is possible given its stock cooling with stock thermal paste etc... I'll probably be getting a Hyper 212 soon. But, any input on the temps and sensors would be much appreciated!
