2500k v 3570k
16 Sep 2011
Northern Ireland
Ok guys, I know a few of you guys advised against upgrading CPU at this moment in time and told to wait for the haswell chips, but I don't think I could honestly afford that chip when released. So basically, which is better? Which chip runs cooler? (I have a Arctic 7 Rev 2 fan)
Both are the exact same price, Thanks !
the 2500k runs cooler
but the 3570k doesnt need as high clock speed for the same performance.
the cpu cooler will be fine for around 4.5 at a push on the 3570k
I would get the 3570k now as its slightly better than the 2500k. or get another couple posts and buy a second hand 2500k off the mm for around £100-£120
The 3570K runs cooler on stock, but the 2500K runs cooler when overclocked.
Both CPUs share the same architecture, but the 3570K uses a smaller process and is tweaked for better performance.
Just get the 3570K, it's the better and newer CPU.
Haswell processors should be released at a similar price point to the Ivy Bridge processors which they replace.
Out of the two, 3570k is your best bet if you want to stick with your motherboard. What CPU have you got in it at the moment?
i5-2320 mate.
Is there a particular reason you want to upgrade? It sounds a bit marginal, especially considering the expense. Then you'll need a decent CPU cooler. And it also depends on the motherboard. unless you have a Z77 (or Z68), it's kinda pointless since you can't overclock.
So all in all, you are looking at an expensive upgrade, for not much gain. Best wait for Haswell, or if you feel it's too slow, look at better alternatives (a 2700K maybe, even more expenses but at least justified).
Some games just run a bit laggy, especially MMO's , and considering that's the majority of the games I play - can be a bit of a problem :p I could probably stretch to the 2700k, if you really recommend it? Or would the gains not be big enough for that sort of outlay?
I doubt the gains are worth the outlay. What GPU do you have?
Define laggy?
MMO's can feel laggy or jerky at times as they tend to try to stream a lot of information from disk to cpu/gpu pretty much constantly.
Are you running from mechanical drives or SSD's?
If mechanical, moving to an SSD would greatly improve the experiance.
MMO performance is often rather CPU-bound and I know from experience that Guild Wars 2- for example- will quite happily eat all the CPU power you're willing to throw at it. If you already have a Z68 board a used 2500K clocked to 4.4 would likely provide a healthy performance boost
Define laggy?
Jerky/stuttery! I would just normally describe it as lag :D Oh reallys? I am running it all from a mechanical drive.
